Hi Tapio,
The only thing I can think of is that the feed rate is being set in the wrong units (mm vs inches).
What Version are you using?
Message: 7659 |
Date: 6/14/2013 |
Subject: Re: Occasional feed rate error w/ Mach3 |
I have Mach ver 042.040 and KMotion 431c.
I also do all feed rates in G95-mm/rev. Native units are set to mm and distance moved is consistently correct.
The preceding rapid move is also consistently correct.
I let the work cycle run on few such errors and the outcome was correct, it just took way longer time.
I did not take any not on the elapsed time, but I will next time this happens. will report back.
Rgds,
Tapio
> Hi Tapio,
> From: tapiolarikka <tapio.larikka@...>
> Sent: Friday, June 14, 2013 7:53 AM
> Subject: [DynoMotion] Occasional feed rate error w/ Mach3
> Hi!
> I have been experiencing occasional feed rate error. Once or twice per some 100 cycle start feed goes very small, as if there was a decimal error in commanded feed rate.
> When I stop the work cycle, rewind the code and start over it works OK.
> All dro's report correct revs/feed rates.
> Has anyone noticed similar behavior?
> Any Ideas where to look for cause/cure?
> Rgds,
> Tapio
Message: 7661 |
Date: 6/14/2013 |
To me it looks more like a hardware rather than a software problem. Maybe some kind of electrical interference. Check list would be: reasonably short shielded signal cables, proper grounding, line filters, etc. What hardware are you using? Is it a new setup or the problem appeared suddenly?
Sorry for bad English, hope it's still clear.
RL.
--- In DynoMotion@yahoogroups.com, "tapiolarikka" <tapio.larikka@...> wrote:
> Hi Tom,
> Rgds,
> Tapio
> > Hi Tapio,
> > From: tapiolarikka <tapio.larikka@>
> > Â
> > Hi!
> > Rgds,
> > Tapio
